kilometres101
kilometres101's Achievements
New Member
New Member (2/5)
0
  1. Hi, I'm aiming to buy a pull-up bar to install on external block and brick. All standard (as new build can be.) I have two problems. The first and most obvious. There is scant info on the web on how to install. I assume anchor bolts are the way, but putting horizontal force on the brick may cause problems? Is there any benefit in load distribution to drilling through the cavity and into the block? Would it be worth putting something else on the wall to spread the load? This leads me to the other problem. The brick is reclaim effect and however nice, is easily chipped. Does anyone know if the compressive strength is any different on these? Cheers
  2. Hi, just looking for advice on some elements of new build construction before starting projects.
