Hi,
	Im new to the site: Stumbled across it when trying to resolve my querry.
	Does anyone know how to account for low emissivity cavities in U-Value calculators? I'm using the BRE calculator, trying to calculate yhe U-Value of the following timber frame closed panel build-up:
		12.5mm Plasterboard
		35x50mm vertical battens to create a service cavity
		Reflective AVCL layer
		25mm PIR Insulation
		38x89mm timberframe studs at 600mm centres, with 100mm lambda 0.044 insulation between the studs
		9mm OSB
		Reflective breather membrane
		50mm Cavity
		102.5mm brick
	I come up with the calculation below, but it seems to me that the reflective membranes on the inner and outer cavities have a far to large impact on the calculation?
	Walter V
