Just now1 min So I'm starting a major back to brick renovation and wrap around extension in January and as part of that I'm looking to get a MVHR installed! Self install if you count just me and my builder doing it together. House is being done to regular building standards but going a bit extra on the insulation and applying Aerobarrier at the end to hopefully get as good Air tightness as possible. Hopefully below 3.Is there a recommended place to go to that will supply a design, MVHR unit and ducting plus other bits and assist with commissioning and certification? IThinking of installing Brink Flair 600 with Ubbink semi rigid radial (oval?) ducting. House volume is estimated by AI is around 480m3 which is why I picked the Flair 600.I did a bit of mucking around with AI and came up with something that looks reasonable which I'm attaching. Thinking of installing in a loft cupboard space directly above two bathrooms and directly below them in the same run is the utility room space which seems convenient. I'm not bothered if there's boxing out in the bathrooms or Utility room as long as there isn't any in the regular rooms. A couple of issues is going through a Steel Beam on two occasions to supply two outlets in the Kitchen/Lounge area (dashed black lines by the stools).Any help is much appreciated. MVHR-location-and-duct-routing-concept (1).pdf
