Just now1 min Evening all.My SB is at the bottom of a hill. As per the attached sketch, rain water runs down the lane until it meets the alley at the bottom, then continues along to our house. In heavy rain after dry conditions, we get mildly flooded. I am not keen on this.It's a relatively recent problem, related to changes in surface treatments along the lane. The lane and alley are not publicly maintained so it's down to whoever cares to fix it. That'll be me, then.As you can see, there's an open drainage ditch running alongside the lane so the obvious solution is to redirect surface water into that. The question is how best to do it.I want to do the redirect in the alley, as that only takes foot traffic, whereas the lane takes cars. The alley is just earth and loose gravel.You can see from the levels datum points that there isn't too much wriggle room, although I probably could reduce the +4 level of the ditch a bit to create more fall.I have considered creating a french drain using some old lengths of 100mm pipe I happen to have, drilling holes in the underside, wrapping it in fabric, surrounding and covering it in shingle etc.My only concerns are whether pipes can handle foot traffic above without getting crushed or damaged, and also handle the volume of water. It can come down the lane pretty heavily and quickly. I think perhaps I would lay two or three pipes side by side to create greater capacity. It doesn't need to hold the water, just direct it, but even so I am concerned that a sudden deluge might be more than the little holes in the pipes can handle.Or, I could excavate to create a sort of little sump falling into the ditch. I'm not sure if the ditch edge might collapse at some point, though.I have also thought of shallow soakaway crates starting at the junction of the lane and the alley, over to the ditch, but that's getting expensive for something in a public alley.Any suggestions most welcome!Thanks
