Unusual UFH System ??
Don't think I've posted on here re this before.
My daughter has this system, installed 10 years ago, works perfectly, The manifold pump pumps downward into the bottom manifold which is the UFH inlet and its some of this (mixed temperature) water that's returned to the boiler and not the UFH outlet "cold" water which is only 5.5C cooler in this case but can often be 7C to 10C cooler which can have implications for the boiler condensing effect and boiler efficiency etc. A oil fired boiler services this + rads & HW cylinder and oil fired boilers should generally not be run at a lower return than ~ 40C so wonder if this type of installation is typically used with oil firing?. I also show a TMV bypass which is installed so presume this can be used to recirculate some boiler flow water into the return to maintain this 40C minimum.
Its a Ivar manifold with a Wilo pump.
I did the calculations based on actual readings.
Edited by John Carroll
