Just now1 min I’ve got what I think is a longstanding problem with damp on my chimney - in the loft and occasionally bedroom below. I’ve only been here 5 years, but I think it’s been a problem all of that time and before. It’s hard to be exact as there was another roof leak close to the chimney until the roof was replaced in summer 2024.When the roof was replaced that also included chimney flashings. Winter 2024 didn’t appear to show any problems (although I didn’t look in the loft for any evidence at the time - so there may have been damp, but I didn’t see it). Winter 2025 we had a very damp chimney wall in the loft and also in the bedroom below, so mid summer 2026 I had a scaffold up and repointed and reflaunched the chimney, then a couple of coats of Stormdry.Storm Austen a few weeks ago showed no issues at all. We’ve not had much rain since, but quite a bit overnight, so I went up in the loft this morning.Chimney wall in loft was quite damp (nothing like as bad as last year), with surface droplets all over the bricks. I checked again after work (it’s been raining pretty much all day) and the surface droplets are gone and although the wall still looks damp, it’s certainly ‘dryer’ than this morning.Given that Storm Austen’s rain and today’s rain don’t seem to have had a negative effect. Along with the fact that the stack was overhauled completely over the past 2 years, yet the problem remains I’m looking at other options (whilst not completely ruling out rainwater ingress)It’s an external chimney breast with a currently unused gas fireplace (gas pipe was disconnected in 2024 but plan to reconnect it soon). There is a stainless liner running from the fire to the cowl. The cowl was replaced this year. There is no insulation in the flue around the stainless liner. As far as I can see there is also no ventilation in this space inside the flue around the stainless liner.I’m considering that it could be condensation inside the flue and/or in the loft. When the cowl was replaced in mid summer, the inside of the chimney pot around the outside of the stainless liner was fairly damp. That despite no rain for weeks before and a bone dry chimney stack. I’m wondering if I should be ventilating the flue.I’m not sure that a damp flue would cause tiny water droplets all over the brickwork in the loft though? Perhaps I have a problem with high humidity in the loft. My issue with this diagnosis is that I’m not seeing condensation anywhere else in the loft - on metal etc. I also don’t have a very humid house as I have MVHR, although I appreciate that despite MVHR warm air from the house moving into the loft could well condense. I do have a pretty ill fitting loft hatch that could be a problem.Hopefully some of you have made it this far. Thoughts very welcome and gratefully received.
