Just now1 min Hi, got a major problem with my disinfection cycle which makes no sense to me, On my LG 9Kw heat pump controls I set the disinfection control to come on at required time and for 1 hour to get water temp up to 60°C When the required time is reached I hear the solenoid click in for the immrsion heater, after 1 hr the temprature has risen about 2° C. the water temp was 50°C to start with.I have checked the flow of current to the immerson heater with a clamp meter which is a healthy 13.5 amps, I have checked the resistance of the immersion heater element which was 19 ohms, I have two more thermometers in the pocket of the water tank which also only rise 2° in 1 hr. I have also tried to check the thermostat on the immersion heater , which does switch on and off and is turned up to the top.Anybody got any Ideas what to check next. Thanks
