October 6Oct 6 Taking a day off from the bathroom job and going to finally tile my internal porch. Be good for practice as well. Everything cut and dry fitted, so now it's time to get to it. I've got Ultra tile Pro Primer, what's the best way to use this? Instructions on the back are rubbish at best, I was going to mix it up with 25% water and then just lash it all over the floor (P5 chipboard with a glued and screwed 6mm ply top). Let it soak in and then crack on with the adhesive. Sound correct?
