https://www.solaredge.com/uk/
Very interesting and confusing conversation with guy who came out to look at the possibility of another PW2
If DNO deny then that's it. As my output/drain ( i.e. charging everything up at cheap rate ) upsets Mr. Grid
With SolarEdge ( as far as I understand it ) the battery storage is before the exporter. So that's currently limited to 3.6Kw. With2 PW2 at 5KW each they could argue 'drain' can exceed what they will permit ( they cou
You can get a device which some manufacturers call a export limitation system, it is basically a module which sits in before your DB and stops export, you buy it and wire it in and program in a dead stop, i.e. nothing.
Each panel is made up of a quantity of PV cells, like a battery, the more you add the higher the output voltage and the more current they can generate, so in a panel you might already have say 80 PV's - when you connect 2 of this same panel together you have actually j
