Hi.
I am looking for some advice on the different insulations options that can be used. I'm building an ICF property, so I've already got wall insulation. It's mainly for the floors and vaulted roof, in between the timbers. I'm insulating the roof of the garage now, with 150mm of Celotex and then I'm thinking of using a foil quilt for the thermal bridging.
PIR insulation is the worst material to work with and I don't want to use it again for the house roof, which will also be a
