I like the look of a manifold type water system, however I have some reasonable long runs for the hot water.
Is there a way of calculating how long it will take hot water to reach the tap from a cylinder.
I will have a measure up today to see what you all think
I understand you can change pipe size to certain things.
But it would like to be able to do a mock up to see if it will work before I dismiss a manifold and start thinking about hot returns.
