Interested to know the difference between these two and their different applications!
All advice gratefully received.
Clear CT1 for that. White silicone will tear and come away if there any movement whatsoever.
DONT USE WHITE CT1! It will go custard yellow If you want a cosmetic ( coloured ) finish simply tool / baby wipe + MultiSolve spray the excess clear away and allow to cure, THEN top coat with a silicone. You simply peel that off every time it gets grotty and the CT1 stays mint for life underneath.
