This is the acoustic board sold by Sydenhams; has anyone used it? Any opinions on this versus Soundbloc?
the main thing you want to look at when comparing 'acoustic' plasterboard is the surface density (kg/m² ), the higher the number the more mass it has and better it performs and a mass barrier
From what i can see 12.5mm GTEC dB is 10.2 to 10.7 kg/m² , and 15mm is 12.5 to 13.1 kg/m².
other boards as below;
Gyproc wallboard 12.5mm - 8.0 kg/m2, 15mm - 9.8 kg/m2
Gyproc fireline 12.5mm - 9.8 kg/m2, 15mm -
