What would you recommend for the last bit of a water connection when using Hep2O? If I have a pipe going up a wall and ideally chased in, should I use an elbow to come out of the wall or keep going with the same bit of pipe and then use something like one of their flexible connectors? That would leave a potentially ugly to plaster around bit though.
https://www.screwfix.com/p/hep2o-push-fit-flexible-tap-connectors-15mm-x-1-2-x-300mm-2-pack/1250f
For showers I am swa
