Figured start a new thread on this as it's a bit removed from "flexible tap connectors" and can stand alone
So I'm boxing the bath in. Just doing what I can until I decide what way around the bath is going etc. It's a timber frame all screwed together so easy enough to dismantle.
Decided to taper the long bath side so when you stand close your toes will be sort of under and you'll be a couple of inches closer. It'll be tiles atop the 3/4" ply that the bath sits on. Up the side (tiled
I tend to put the seat level at 425mm. When I demonstrate the slightly higher ( referred to as 'comfort' ) height most older customers say it's much more forgiving.
I would choose the 420mm option every day, regardless, and don't like a low toilet.
Kids can use the chuck-away 'pee step' when their little legs don't reach, but...... "a loo is for life, not just for Xmas"
