Figured start a new thread on this as it's a bit removed from "flexible tap connectors" and can stand alone
So I'm boxing the bath in. Just doing what I can until I decide what way around the bath is going etc. It's a timber frame all screwed together so easy enough to dismantle.
Decided to taper the long bath side so when you stand close your toes will be sort of under and you'll be a couple of inches closer. It'll be tiles atop the 3/4" ply that the bath sits on. Up the side (tiled
a) Fill it to the brim to simulate you sitting in it whilst it's full. b) Once solvent weld has gone off that's the end of the show mate. You'll be able to tow a car with that, a few knocks won't matter a toss. Adding glue will just create a skin which won't do anything whatsoever and will just peel away once cured.
A bit more to this one. In your left hand you have the 'plughole', and two rubber washers. I usually ditch the upper one and make that up entirely out of sika. The conical on
