Hello There,
Could someone provide me with advice how to properly install a glass within wall channel?
I had an installer that has done this before but he has done completely terrible job, that I had to purchase a new set of channels as he covered everything in silicone and ripped apart the knock on seal.
So I removed everything and want to do the job properly.
I have instruction from manufacturer but I am not sure where the gasket goes, looks to me that it should be i
You MUST fit the channel onto a wet bead of CT1 / clear silicone ( I only use CT1 for this as silicone has a limited life ) otherwise water collects inside the channel and will find its way between the wall tile / panel and the tray and soak into the wall. This has to be the most common F up I see on a lot of jobs, mostly insurance claims after it's gone rotten
Offer the channel up dry and hold it in place, level, and use bits of masking tape as runway markers, mark and drill holes, clean
