Our structural engineer is insisting on me skinning both sides of our lateral walls with OSB for racking strength. It struck me that if I could make the OSB on the inside air tight I would not need to cover it with a membrane. The challenge is making OSB air tight and I wonder if just painting it, either flat before installing it or once installed, with a thick PVA mix, or some such, would do the job. Any thoughts?
