Have ASHP and cylinder, currently operating on an on/off signal from thermostat, with a signal being sent wirelessly.   Want use the digital input terminals on the heat pump for a different purpose, so need to connect a PT100 probe.    Does anyone know how I can transfer a PT100 probe output wirelessly to the heat pump - is it possible.  I have home assistant if that's any help
