Tomorrow I go back to work after 2 months off.
Now I have totally wasted that time, so thought I better catch up with a little experiment I had in mind.
With some old 9mm OSB, I made a 200mm deep beam.
It is 2.26 m long, and held together with cheap PVA 'no nails' type adhesive (cost a quid a tube).
The flange is 100mm wide.
One flange is 2 layers of OSB, the other is 2 strips of timber, 20mm by 35mm holding the other flange in place.
To test it I put a box on it an
