Figured start a new thread on this as it's a bit removed from "flexible tap connectors" and can stand alone
So I'm boxing the bath in. Just doing what I can until I decide what way around the bath is going etc. It's a timber frame all screwed together so easy enough to dismantle.
Decided to taper the long bath side so when you stand close your toes will be sort of under and you'll be a couple of inches closer. It'll be tiles atop the 3/4" ply that the bath sits on. Up the side (tiled
Cheers. But...I won't be buying one!
SWMBO informs me she doesn't add "blue" stuff to the cistern but sometimes bleach. She CLEANS the bowls and adds blue stuff there. I was informed of this with the hint that I moight try cleaning the loos occasionally. Amazing, I always thought a fairy did it!
So I'm thinking a tube (not 20mm conduit of course) coming up from a boss:
That pokes thru the timber and comes out thru the tile somehow where there's
