I was reading heatgeek.com and they mentioned that many heat pumps with advanced weather monitoring don’t need an internal thermostat or temperature probe to work out the internal temperature for modulating the heat pump:   “Advanced weather compensation can obtain accurate room temperatures without any internal reference once you've dialled your weather compensation curve in.  This means it continually runs rather than being flicked on and off by a thermostat, which minimises flo
