Shedxtension
Onoff
Want to put some slip pins in between old and new slabs. Cut some 200mm long st/st rod and made some indents over half the length with a 3mm disc to key the resin. Other, smooth half will get a wrap of Denso tape to protect from the concrete.
I have a Titan mains powered SDS drill.  Nearly 20 years old now, battered and well used but still going.  On it's third set of motor brushes, and second (much longer) mains lead.
I guess most people would have binned it and called it rubbish when the first brushes wore out?
3 hours ago, Onoff said:
B@ll@cks!
I spoke too soon. Looks like I looked at my test stick too soon earlier today. Faint second line but it's there:
I was surprised as still a little chesty.
And that's why "proper" lateral flow tests use a reader...
So the app says based on start of symptoms I can stop self isolating tomorrow, the 18th. Great, back to work, pub etc.
However if I'm still testing positive with a bit of a cough then surely I'm still infectious? I might not cough, sneeze all day but it only takes one surely? Even when my cough has all but gone...
This arbitrary 10 days self isolation seems more like a way of getting the country back to work with an underlying risk of still infected people spreading it.
This is where I get bored and it starts to go slow. Doing the hardcore, got bloody great lumps I'm breaking up with a club hammer to get sort of level before the sand blind. Boring as Hell. It'd be much easier if smaller bits to start with.
I've about 7 or 8 jumbo bags of assorted rubbly crap. Debating hiring a crusher one weekend to turn into a nice pile or ready to use Type 1, 2 esque. Would be handy when I do my drive.
Blinded it with some all in one. Went over with the little Evolution electric whacker (the 5kN one). I'll round up a load of small sand, ballast etc plastic bags to lay down before the DPM as a bit of protection against some of the sharper stones:
Still debating casting the dwarf wall...
Edited by Onoff
Found a good few 100mm Celcon blocks lying around, more than I thought I had. A bit of greenery on them, a few cuts and corners knocked off a couple where the faces have spalled. Some stock bricks too. I reckon I've enough to do a 3 sided dwarf wall similar to what I did for the original shed. Two things I'm concerned about though:
1) How to stop damp coming through them? Angle the dirt away, a bit of membrane tacked to the walls, French drain, gabions filled with flints etc?
2) The return corner where the pipe for (possible future) electrics is, that'll only be like a foot or so long then a doorway. Worried about an opening door cracking up that brick / block work corner...put the hinges the existing shed side?
Hope that makes sense I'm on the 5.5% St Austell IPA!
