oranjeboom Posted May 16, 2019 Share Posted May 16, 2019 Really don't want to spend £800 on a unit, so have been looking out for used units. There's a local one up for grabs which needs a new Harveys h20 twin tank (not electric): Regen: 17; Resin BS How does that tie in with hardness levels? If not adequate, can I change any settings on the unit? @PeterStarck I recall you had a Harvey with your hardness at 320ppm (mine is 301) - are you able to reset the regeneration cycling/timing? Currently sold as spares as according to the chap selling it, the riser tube ( described as 'the small tube that runs from the bottom to the top external to the two big tanks') is cracked. Would that be this part? https://www.wrekinwatersofteners.co.uk/wrekinwatersofteners/final.asp?id=1906 I know @JSHarris has some experience with repairing these units. Are these fairly easy to repair or engineered in such a fashion that you have to break it even more to repair it? If this unit can deal with hardness just over 300ppm, I'll have a visit this weekend to inspect it. Link to comment Share on other sites More sharing options...
Jeremy Harris Posted May 16, 2019 Share Posted May 16, 2019 Failure of the fill valve at the side was fairly common on the early models, I believe. There's a replacement upgrade kit available from Harvey. My spare unit has the older style fill valve (looks like a tube on the side, between the two tanks) and that's cracked too. I believe that you can get the unit refurbished for around £350 or so, so if you can get this cheaply it is probably worth going for. Refurbishment involves replacing the resin and the fill valve, plus servicing the (hellishly difficult to reassemble) water meter/valve assembly. There are (I think) either two or three different water metering heads, to deal with differing water hardness. All that changes (I think) is the volume of water that runs through before regen is activated. Ours are both set to 750 litres before regen, and that's written on the internals, I think. I don't think this can be changed without changing the water meter head, but I may be wrong. Link to comment Share on other sites More sharing options...
oranjeboom Posted May 16, 2019 Author Share Posted May 16, 2019 Hi Jeremy - thanks for the valued input. I'll probably go and have a look tomorrow then and see which tube is cracked precisely. I think as it's a local unit, the water head will be set to high (I hope) in which case good for me....as long as I can get it to work. I don't really have time to be faffing around ("just buy a new one.....") but a few hundred saved will help in other areas. Link to comment Share on other sites More sharing options...
Gone West Posted May 17, 2019 Share Posted May 17, 2019 11 hours ago, oranjeboom said: @PeterStarck I recall you had a Harvey with your hardness at 320ppm (mine is 301) - are you able to reset the regeneration cycling/timing? I told the supplier the hardness level in my area and had the hardness setting set by them but I don't know how to reset it. I had an old TwinTec that packed up a few years ago and gave it away on Freecycle for someone to play around with, I was too busy doing the house at the time. I did look on Youtube at how to replace the resin but it seemed like too much hassle. Link to comment Share on other sites More sharing options...
Gone West Posted May 17, 2019 Share Posted May 17, 2019 @oranjeboom On mine it says regen 23 and resin 400. I think yours might be possibly 135 not BS. Link to comment Share on other sites More sharing options...
Oz07 Posted February 10, 2020 Share Posted February 10, 2020 What did you do in end @oranjeboom Link to comment Share on other sites More sharing options...
oranjeboom Posted February 11, 2020 Author Share Posted February 11, 2020 I went ahead and purchased the unit for about £40 iirc. Approached a local softener company who had two older units that were in the skip so kindly gave me the riser pipes from both of them. Easy to replace, but not actually plumbed the unit in to test. On 16/05/2019 at 21:13, Jeremy Harris said: Refurbishment involves replacing the resin and the fill valve, plus servicing the (hellishly difficult to reassemble) water meter/valve assembly. I may still have to do that also....if Jeremy is referring to the same part that I have changed. Bought some salt last week so will just place that in the unit, get it to regenerate and then see whether the unit provides softer water! 1 Link to comment Share on other sites More sharing options...
Jeremy Harris Posted February 11, 2020 Share Posted February 11, 2020 The fill valve is the pipe thing mounted on the side, between the two tanks. It's a type of float valve, that sets the level of brine in the outer tank. If the resin needs changing then it's not that difficult to do, it's just a bit fiddly. There are resin fill ports on the tanks, at the top. Hardest bit may be flushing the old resin out of each tank. The challenging bit is if the water meter develops problems, or the O seals on the valves it controls need replacing, as it's a night mare to reassemble. When you connect the thing up, with salt in, do two manual regenerations once the salt has had time to form brine in the tank. To do a manual regen, fit a screwdriver in the white slot on the top of the water meter, push down against a spring and rotate the white bit clockwise through 360 degrees, until it pops back up. You will hear it start to regen one of the tanks, a process that takes ten minutes or so to complete. Once it has finished regenerating one tank, repeat this process to regen the other tank. The need to do this is largely because you don't know the state the unit is in, and this ensures that both tanks are fully regenerated at the start. The unit is then set up and ready to go. 1 Link to comment Share on other sites More sharing options...
oranjeboom Posted February 11, 2020 Author Share Posted February 11, 2020 (edited) Thanks @Jeremy Harris. Okay, it was actually one the the riser pipe that connects to the bottom of either tanks: Easy to replace but had to change one of the rubber O rings as it kept leaking when i tested it. Looks as though someone had drilled through outer case of the unit to fit a drain point and drilled too far and hit the riser pipe! Fill valve looks okay but is set at 300g. Think I read somewhere that is determined by water hardness in your area and can be swapped round (which I may have to do, i.e. 350g). 1 hour ago, Jeremy Harris said: If the resin needs changing then it's not that difficult to do, it's just a bit fiddly. There are resin fill ports on the tanks, at the top. Hardest bit may be flushing the old resin out of each tank. Okay - hopefully resin levels are still fine. Guess I'll see how the unit performs when plumbed in. The resin itself seems to be Purolite which has a nice price tag! e.g. https://www.aquasoftsofteners.co.uk/aquasoftsofteners/final.asp?id=1146 Haven't really been able to find any servicing manuals, but it's all a bit of a closed shop - anything goes wrong and you either have to tinker with it yourself or take it to an authorised dealer. Just glad I didn't pay £800 for it! Edited February 11, 2020 by oranjeboom Link to comment Share on other sites More sharing options...
Jeremy Harris Posted February 11, 2020 Share Posted February 11, 2020 The good news is that the unit is one of the newer ones, with the redesigned fill valve. The original fill valve fitted to the earlier models looks quite different. The resin is probably fine, it's pretty robust and will tolerate a fair bit of abuse. About the only thing that will kill it is if someone has decided to flush something nasty through it, like neat bleach. 1 Link to comment Share on other sites More sharing options...
tommyt Posted February 11, 2020 Share Posted February 11, 2020 11 hours ago, Jeremy Harris said: If the resin needs changing then it's not that difficult to do, it's just a bit fiddly. There are resin fill ports on the tanks, at the top. Hardest bit may be flushing the old resin out of each tank. Changing resin on these is pretty fiddly due to the small ports. They use a packed bed and it is blown in at the factory so you’ll never put back in as much as comes out. Being a packed bed though makes it more easy to identify resin degradation. If the resin has become damaged by chlorine from mains water it tends to break down and expand. Once you’ve got the resin wet and flushed, turn off the water supply again and using the method Jeremy noted to manually regenerate you can relieve the water pressure inside. Then just remove the filling ports and if resin starts rising upwards out of the hole then it’s had it. If it stays at the lower edge you’re good to go. I’m on a job this week adding 325 litres to each of 9 2500litre softener vessels which were under filled when built and we are literally just pouring bags of Purolite straight into the 6” wide necks from above whilst standing above on a scaffold. 1 Link to comment Share on other sites More sharing options...
oranjeboom Posted February 11, 2020 Author Share Posted February 11, 2020 Thanks @tommyt! I'll see how it performs before i open up the unit. Hope you get a better (bulk) price for Purolite than the online prices! Link to comment Share on other sites More sharing options...
tommyt Posted February 11, 2020 Share Posted February 11, 2020 3 tonnes direct from Wales. And we’re having to give it away for free including 4 days labour for me and another person plus re erection of the scaffold due to the original install mess up. So I hope we’re getting it cheap. Link to comment Share on other sites More sharing options...
Flagooner Posted June 12, 2020 Share Posted June 12, 2020 Hi hope I can slightly revive this topic to get some help. Bought a used Harvey’s H20 a few months ago. Installed it outside the house next to the drain, boxed it in etc. Worked fine until about a week ago. I heard water constantly dribbling into the drain from the brine outlet pipe. I took the ends off the valve assembly but found nothing. Really need help on this please as emptying buckets of water onto the lawn and on a water meter. Link to comment Share on other sites More sharing options...
Jorge Posted June 12, 2020 Share Posted June 12, 2020 Hi @oranjeboom, Hope your watersoftener is working perfectly. Considering the very experienced subscribers of this thread, I would also bring up a issue I have with my softener. I have bought a used Harveys 2 cylinder non electric watersoftener, installed it myself on my previous property, and it worked for 2 weeks. Similar to what @Flagooner has described, it worked ok for 2 weeks, and then started sending all the water through the drain. Found it weird, and did a manual regeneration, which worked for a a few days. Then it all started again, sending the water straight to the drain. It has been off since. Couldn't never find the reason why it fails after a few working days. My wife keeps telling me it must be something wrong with the resin, but obviously I'm not a specialist, so I haven't tried to open it yet. Now I'm wondering if I should try to fix it, given that water is quite hard at the new property I have moved into and it's already creating loads of stains on all the taps and shower. Link to comment Share on other sites More sharing options...
Flagooner Posted June 12, 2020 Share Posted June 12, 2020 Hi Jorge when you say “ sending all the water down the drain “ is that a powerful flow or just a trickle? I have just spoken to a Paul at Wreakin Water and he is not certain what the problem is but suggested I try a new shuttle valve assembly and service kit for the idler gear. Quite a lot of money involved in that, £160. He did also say that in older machines the resin could expand and cause this problem. I was hoping that Jeremy Harris might be able to help, I don’t know if he still monitors this site. Link to comment Share on other sites More sharing options...
Jorge Posted June 12, 2020 Share Posted June 12, 2020 Hi @Flagooner For me it seems more like a powerful continuous flow. Initially I thought it was a regen, but after 1 hour decided to turn it off, too much waste. Link to comment Share on other sites More sharing options...
oranjeboom Posted June 12, 2020 Author Share Posted June 12, 2020 4 hours ago, Jorge said: Hi @oranjeboom, Hope your watersoftener is working perfectly. It's one of those jobs I have been putting off as I have a feeling it's all going to go wrong. I'm hoping to work on this in the next week or so. Will report back. But yes, @Jeremy Harris is one of the experts on here on the Harvey units. Link to comment Share on other sites More sharing options...
Flagooner Posted June 14, 2020 Share Posted June 14, 2020 Hi orangeboom can you tell me the company who were throwing away old units I would like to contact them to see if the have any used parts for mine, thank you Link to comment Share on other sites More sharing options...
oranjeboom Posted June 14, 2020 Author Share Posted June 14, 2020 5 hours ago, Flagooner said: Hi orangeboom can you tell me the company who were throwing away old units I would like to contact them to see if the have any used parts for mine, thank you They were a local Kent company. Will PM you the details. Link to comment Share on other sites More sharing options...
spaceman Posted November 1, 2020 Share Posted November 1, 2020 My H20-750 softener has developed a fault, part of which includes constantly draining. I created a new post with all of the details but thought I'd add a redirect to it on this thread as there seems to be some contributors in here with applicable experience/knowledge: https://forum.buildhub.org.uk/topic/17282-homewaterharvey-h20-water-softener-developed-fault/ I would really appreciate any help on the likely faulty component, and advice on the way forward. Thanks. Link to comment Share on other sites More sharing options...
Ish Posted January 11 Share Posted January 11 I have bought a second hand Harvey unit and wanted your help to understand the setting correctly. I was quite a recent unit and was in good condition. I have installed it myself and have been working fine. The only issue is that it runs the regeneration cycle quite often. Once or twice a day. Is that normal? I have checked the water quality and I live in a Very Hard Water area. Link to comment Share on other sites More sharing options...
OldSpot Posted January 15 Share Posted January 15 On 11/01/2024 at 11:11, Ish said: I have bought a second hand Harvey unit and wanted your help to understand the setting correctly. I was quite a recent unit and was in good condition. I have installed it myself and have been working fine. The only issue is that it runs the regeneration cycle quite often. Once or twice a day. Is that normal? I have checked the water quality and I live in a Very Hard Water area. Which Harvey unit is it? The ones I have seen (mainly S3/HV3) don't have that rotor with left & right on and have a slightly different layout on the top. I'm considering buying a Harvey so would also be interested in what the numbers in the boxes below "Service"; "Regen"; "Resin"; & "BV" mean if anyone can help. Link to comment Share on other sites More sharing options...
