HDMI Crimp
There are solder repair connectors available but I've never used them. Will need a small iron with fine tip.
https://www.ebay.co.uk/itm/HDMI-Male-19-Pins-Connector-A-Type-Solder-Termination-Repair-Replace-Kit-5-Pcs/162962886822?epid=1538358618&hash=item25f15850a6:g:jyUAAOSwfuBazLNs
I don't see any instructions.
edit: or a backshell?
Edited by Temp
We had a similar issue a few years ago.  Both HDMI leads within a month of each other.  I googled, I watched you tube then we hacked away at part of the wall and fed through the new cable where we could.  It was a nightmare.
Edited by Sue B
  • 2 months later...
