Weather Cock
Triassic
The house is up and the designer has asked if she can have a weather cock!
looking on line it’s not clear to me how they afix it to the roof, has anyone installed a weather vane and if so how ?
She wants it to sit on top of here
Edited by Triassic
Nice idea. Very nice idea.
The rafters are exposed (albeit under something like Kloeber Permoforte) ? There will be some fitting that works well - use that - and then cap it off with code 5 lead?
As usual, I'm short on detail.....
On a different note, could you consider a locally made one designed for *you*, rather than a generic cockerel ? Should not be horribly expensive compared to a house. I would love to have the chance to do one of those eventually somewhere, but at present I just have inherited gryphons.
Personally I would be tempted by something like a bicyclist or a local artisan, or even Duncan Campbell on his lake.
But make it worthy of the work and time you have spent building the house; you deserve that fillip.
Ferdinand
Edited by Ferdinand
One thought - will you need Planning Permission, or a variation?
Here's a place that do Occupation-based weathervanes, including hundreds of professions:
https://www.weathervanes.co.uk/category/weathervanes/occupations/
Cost is £150-£500.
Heating engineer:
Bricklayer
Shaun the Sheep
12791082_1020931901286346_10071533927716
(I think they have photoshop ?)
Ferdinand
Edited by Ferdinand
Nice video @Ferdinand Now for the technical stuff.
I like the idea of making a weather vane, I also want to keeping things local.  I need to make the mounting rod that fastens to the house. So, what diameter is the rod sticking up from the mounting plate. I assume it’s solid and the weather vane tube is hollow and slides over it?
42 minutes ago, Triassic said:
What’s the likelihood of lightning hitting a copper weather vane? Would I need a conductor to earth?
In the world of sailing it is claimed that when a yacht has an earthed mast (big wire electrically connected to a metal keel) then a spiked lighting rod at the top of the mast will discharge a stream of ions in conditions that could lead to a strike. The net result is that a yacht moves within a bubble of reduced electrical potential which persuades a lighting strike to find a path to earth elsewhere.
Edited by epsilonGreedy
Info as b****** f****** w******* Apple just deleted my post.
Professional Lightning Engineers’ Body
http://www.atlas.org.uk/
Ecclesiastical Insurance advice, who insure churches
https://www.ecclesiastical.com/risk-management/church-lightning-advice/
https://www.ecclesiastical.com/documents/lightning-protection-guidance-notes.pdf
F
