Foil faced insulation underfloor
BMcN
Morning,
With regards to PIR insulation when placed under floor, does it matter about being foil faced?
My floor will be concrete slab / DPM / 120-150mm PIR / UFH pipes / 75mm concrete screed.
If the answer above is yes, is there anything I could use on top of the PIR to replicate the foil face, like an aluminium VCL like this?
Thanks
Nope. Just put a thin plastic slip membrane between the insulation and the concrete.
That's what I am hoping, I'd be able to reduce the cost of insulation quite a bit by going without foil.
17 minutes ago, BMcN said:
What's the thinking behind the double dpm? Just to save on messing around with blinding?
No, there is a danger that the insulation will undergo hydrolysis (breakdown to its constituent chemicals) in permanently damp/wet conditions.
http://blog.celotex.co.uk/technical/what-celotex-insulation-can-be-used-in-floor-applications/
Sorry I got confused as I misread Peters post.  Yes dpm then PIR then another dpm to protect from screed.
Why the recommendation of 25mm eps instead of blinding?
16 minutes ago, PeterW said:
It’s just easier than sand blinding and protects the DPM from punctures.
Thanks.  I'll see what depth I have as the hardcore is in and compacted but I can't remember what depth I have left to the FFL.
