How much does sand compact when plate compacted?
Digmixfill
I've started to barrow in the hardcore for my floors, and very pleasing it is too to finally see something other than dirt :) 130mm is whacking down nicely to 100mm.
I don't seem to be able to turn up any info on sand compaction. How much sand do i need to put down to have a 50mm layer after compacting?
On 21/02/2019 at 08:08, Russell griffiths said:
Just be careful not to be too over enthusiastic with the whacking, it is possible to move thin walls by compacting tight up to them, outer load bearing should be fine.
If you have any thin internal walls fill both sides evenly and whack both sides evenly
Fortunately i've not got anything to worry about movement wise. All the internal perimeter base blocks are solid concrete and they're filled between them and the 9 inch external walls. Three internal walls are 9 inch load bearing too.
I don't think i've been too enthusiastic.  Six passes with the plate have so far compacted the mot1 sufficiently.
On 21/02/2019 at 06:53, PeterW said:
It only needs to blind the gaps in the stone so you don’t need a lot. You can also use a layer of 25mm EPS below the DPM which does the same job
My plans have 50mm, but I'm more than happy to barrow less :)
25mm EPS is i nice idea, but the prices i have for 8ft boards make it much more expensive than sand. a LOT less barrowing though!
The eps boards you use under your dpm aren’t wasted, you just subtract the amount from your final insulation layer
so if you are having 150mm for arguments sake, you still use 150 mm but 25mm under the dpm to protect it then another 25mm on top of dpm then another 100mm.
So total 150mm you have just trapped the dpm in between the bottom two layers.
Minimal sand, just a very light dusting to take out any undulations, then lay your first board.
@Onoff Is that a concrete edge to the top and right of that room? If it is, did you EPS that also?
I don't think i can subtract any EPS blinding from my total. There's another slab before my floor insulation.
I have a picture here showing construction. floor construction
The hardcore and lower slab are now 100mm and the insulation is 200mm.
Only just read this sorry! The concrete edge is where I shuttered and squared off the wall footings to make it easier to eps it.
Selection_192
Eps over the concrete edge, stuck with Soudal low expanding foam. The inner leaf dpc is at the joint just under the pipe which was originally the room's ffl. That incidentally was 60mm higher in places than the rest of the house, to correct this was one of the reasons I embarked on the "big dig".
SAM_1120
I painted the blocks up to the dpc with liquid waterproofer then chucked dry sand at the second coat:
SAM_1132
Then glued perimeter eps on with Soudal low expanding foam:
SAM_1507
Imho I think your 50 sand blind is way too thick.  I just got my hard-core v.level and the sand was just a token thing. The eps does all the work protecting the dpm.
Edited by Onoff
I'm just as bad. For some reason i don't get alerts for posts, so i don't check the site as often as i should...
I've got something similar along one wall where the underpinning is a bit high.
I'm of the same mind, but when i enquired with building control about increasing insulation by dropping the thickness of hardcore & lower slab they didn't offer changing the blinding layer, or even comment on it.
I've done nearly 40sqm so far. That's roughly half way. If it is to change it's now or never.
