Building regs
Sjk
Hi all,
I just want to make sure I have this correct in my mind.
So I get a SE to draw up some technical drawings, then pass these on to LABC (other providers are available) who give the initial "all clear", then they inspect the build at various stages to ensure compliance?
How many of you have opted for using the same company for inspections and warranty?
Thank you in advance
Not sure if this helps, but I did my own building regs "full plans" submission, using LABC, and all the documents I submitted can be downloaded from here: http://www.mayfly.eu/2013/09/part-fifteen-the-site-is-finally-ready/
It may give you an idea as to what they need to see, although this will vary a bit with different build methods, I'm sure.
We had a Build Zone 10 year structural warranty, who used BBS Building Control as approved inspector.
I think it saved us a bit on costs (can't find the comparison figures), but our building inspector was excellent. This made the whole process pretty painless.
You make it seem so easy!
