Blocks - Thermal Values
wozza
Hi All,
Quick question to the experts:
What is the difference between these blocks? Why are they measured differently?
Block 1 - Thermal Value (at 3% moisture)        k = 0.24W/m°C
https://www.plasmor.co.uk/uploads/files/Brochures & Data Sheets 2017/Product Data Sheets/Building Blocks Data Sheets/Ultra Lightweight Aggregate Blocks/F127_PDS_FIBOLITE_W03_17.pdf
Block 2 - Thermal Conductivity (K Value) 0.25 (int) – 0.27 (ext) W/mK
https://www.bpindex.co.uk/res/pdfs/b5c123b13c1df9.pdf
Block 1 is measured in W/m°C
Block 2 is measured in W/mk
Whats the difference, which has better performance?
Thanks,
Wozza.
Thank you Peter, that explains a lot, I was wondering if I needed to convert one to the other or if it was metric vs imperial.
Edited by wozza
First post sounded sarcastic and it wasnt meant to be
