Flexible pipe .
pritch
Hi
I need to route my pipes through some tricky areas to get back to my manifold for my new extension.
The ufh pipe I've used before is quite rigid and I think I may struggle.
Is there anything on the market that has similar flexibility to a garden hose ?
I'm sure I've seen something similar being used on a house building program but I can't seem to find anything.
Thanks
Hi and welcome.
Beware over bending this pipe as when heated it will lose a bit of its rigidity and may subsequently kink. Check with the various manufacturers about the minimum bending radius and keep to that.
Get an off cut and practice bending / forming bends to see how tolerant the pipe is to ascertain how far you can go with it.
  • 1 year later...
