Just another damn error...
I was glad I didn't do a final check  for level when I stopped working on the mezzanine joists last night. I would have had another really bad nights sleep.
Look at this.... this is how un-level  I managed to nail the joists hanger: no, the red laser line isn't disappearing to infinity, it's 30mm out at one end and 0 on the other - over 2 meters
For those of you wondering what self-build does to you - it makes you tired enough to make significant - and sometimes costly- errors
All I had to do last night was
  • recognise how tired I was
  • tack the joists in position with cramps and one or two nails
  • go home
But no, I had to hammer home 24 nails on the joist hanger with one end of the joist 30mm too low.
In the cold light of day it beggars belief .
The remedy?
Make a 2 meter long stealer piece (wedge) : half a day's work
and thank God for Debbie's Christmas cake.
At 10pm last night I was about to cut a hole in the only working foul drain on site to fit a boss and merge in the grey water drainage from the static caravan. Then I thought if I get this wrong it is back to bucket & chuck-it in the morning. I put my drill down, called it a day and slept well.
1 hour ago, Construction Channel said:
On the bright side, at least you are getting out there and doing it. I am really struggling to drag myself to the house atm. ?
Been there, know the feeling. I gave up bothering for a week or so until I felt like it. Guilt free, conscious decision not to go or try. Did things a liked including bugger all. Plus some vitamin B50 tablets helped.
  • go home
The remedy?
Done this too! 10 studs at 2570? no bother. wham bam. Huh? Eh? Oh.... 2750.
I'm hoping a couple of weeks skiing next week will revive my enthusiasm ??
Or just pack the end of the support beam up by 30mm! Job done!
Edited by Triassic
Typo
