Shower recess - are Marmox or Schluter Kerdi products worth using?
  • 1 year later...
On 16/01/2019 at 14:57, Weebles said:
We are looking at putting in shower recesses into our showers.  Are these prefab boxes worth it?
https://www.kerdi-board.co.uk/shower-niche.aspx
https://www.pureadhesion.co.uk/marmox-niche-300x400x100mm.html
If so, anyone got any preference?  Thanks
which one did you go for eventually? What's the configuration? We're designing ours now, too many options!!
Never seen these but they are a good idea.
Without checking the details myself, do they com3 in different s dims? 85mm is shallow once tiled.
I made my own (marmot and orbry board) Openings with tile sizes in mind to try and limit cut edges and to fit mosaics. I did hav3 the luxury of a large cavity
Edited by SiBee
Added pics
  • Like 3
Moisture resistant plasterboard is ample, if used sensibly and in conjunction with a tanking solution.
Why spend stupid amounts of money on something that requires tanking ANYWAY?
If you want something waterproof then cement board ( Aqua panel etc ) is a one-up option but if you’re tanking is still overkill imo.
Ive a 1/4 century of high-end bathroom installs under my belt btw, so am not making these comments without care and confidence. ;)
Made mine under instruction of His Highness the Welsh Wizard:
Timber frame:
20180505_145058
Lined with Aquapanel:
20180508_203859
20180606_202358
Tanked:
2018-08-10_09-16-52
IMG-20190111-WA0010
If you want a really big pocket you likely won't get a former anyway.
They are expensive for what they are . But takes 2 mins to install . They have a collar that surrounds them which I’ve yet to install . Joints on the board have some special mix you use . Boards are described as water resistant rather than water proof . Still if the water has got past your tiles / grout / Mastik you’re in trouble anyway .
Interesting. I reckon I could fill my tanked pockets up like a pond.
