Insulating an existing corrugated roof.
Dee J
Pondering the feasibility of a cost-conscious conversion of a workshop building to residential, and one of the key points would be if we could retain the existing roofing. So its a fairly conventional pitched roof with timber A-frames and purlins covered in cement fibre corrugated sheets. It was re-sheeted recently enough for it not to be asbestos. Currently its insulated in about 75mm of kingspan and clad in 9mm ply.... ok for a workshop, but insufficient for residential. Also we'd need to integrate some proper insulated skylights to replace some sections of transparent sheeting. Any advice?
Thanks.
first stop is building control regs to see what is minimum insulation value on roof and walls ,and is there a dpc in floor+ walls  of  the building
any conversion you make will have to comply with CURRENT requirements for a habitable dwelling  -as it is a change of use ,you may even find that the roof structure will not pass for a dwelling  if it was an agricultural building to start with .
