Second hand solar panels
Evening.
A lad near me is selling hundreds of second hand solar panels off a solar farm,the surface of the panels are all scratched and marked, he said they are all working at about 80% capacity.
Now im not thinking of the house, but can anybody think of uses around the garden, 3-4 of them on the shed
1 to trickle charge the electric fence
1 to run a pond pump
come on you boffins are they of any use.
Guest Alphonsox
14 minutes ago, Declan52 said:
Didn't know ozzy was big in the renewable energy market.
I think the Pigeon/Dove/Bat control business dried up in the late 90's - It's good to see he's managed to diversify into sucking the light out of the world.
2 minutes ago, Russell griffiths said:
How about I contact him and ask for a bulk purchase price.
I was wondering if there was someone close to him that could do that.
It's a big ask to go and make a bulk purchase and then put them on pallets for distribution (palletways for instance about £100 to get a pallet up here)
But if someone is willing sign me up for 30.
I would be nervous just sending money to a stranger then finding they were completely dud, someone would have to have a look and take an educated guess on the condition, perhaps take a multimeter and check open circuit voltage on a few?
Any thoughts on the ones from Bimble with the "degraded backing"
This is their picture
As I understand it, that backing material is supposed to be a continuous sheet.  It appears to be cracking along either the individual panel joints, or the interconnecting tapes.
They say the panels are still generating the expected power.
Is it a matter of just doing something to seal it up to keep moisture out so prevent the panel degrading?  If so what with?
Looks easy enough to seal up.  I'd have a look at seeing if the panels can be laid dead flat and then pour a thin layer of the very runny two pack polyurethane or silicone potting compound.  I had a go at encapsulating some home made panels using the water-clear (expensive!) potting compound that Dow Corning make, and it runs freely over a surface and ends up as a nice thin layer, like a conformal coating.
A brush-on silicone conformal coating, like the stuff used to protect circuit boards may be just as good, but that normally needs to be heat cured.  You may be able to set up a rig with a radiant heat lamp to cure the stuff, though.  Whenever I've coated circuit boards with the stuff I've cured it in the oven, doesn't take much in terms of temperature, but does take a while.
If the price, plus the messing about to seal up the rear surfaces, is right, then I reckon they would be a good buy.  I could do with some now, as I'm typing this during (another) power cut, with the house server, modem, router etc running on my back up battery system.
  • 3 weeks later...
Well I ended up with a pallet of 25 of the Bimble solar PV panels. They had listed one on ebay and I won it for a little less than the price they are listed on their website that with transport works out at £50.8 per 250W panel, or 20.32p per watt.
I was pleasantly surprised unpacking them.  Most of them seem fine with no problems with the backing.
One has a split in the backing about 1cm long, and 2 of the panels have the backing peeling at the top edge in one small area like this
I think my "fix" will be to cover the affected areas with a bit of sticks like sh*t smoothed down with a finger.
