Window Companies Alu Timer/Alu PVC
canalsiderenovation
No it is:
JUB External Render Only system with a silicone finish; two coat application; circa 3mm
thick nylon mesh reinforcement fully bedded in base coat, overal thickness 12mm
(approx); white; applied to Econekt King Blok base; full preparation, bonding agent and
application strictly in accordance with manufacturer's guidelines and recommendations
from the contract.
