Cut timber preservative: wall plate
ToughButterCup
On our flat roof, it looks like I need to join two sections of wall plate together. Thanks to everyone on this thread
I'll make the join so that at least three joists are resting on the plate (NHBC Standards 2018, 7.2.6 Wall Plates). (Thanks Gary @nod  )
The same guidance suggests I should use a coloured timber preservative (7.1.4)
And I bet they don't mean the stuff you get from B+Q. An Internet search gets a flurry of probably irrelevant results.
Do they mean the blue color stuff you get on roofing battens? Ideas anyone?
Yes Ian or something simalar
If the tin is nearby when he next visits It will not be an issue
1 hour ago, Oz07 said:
never seen anyone coat a wall plate joint with preservative, rarely see tantalised timber used either (trusses generally not preserved).
Are you preserving the wood or teasing it!! ?
