Oh bugger, tiles lifting.
joe90
Well I am not a happy bunny, my kitchen diner was tiled a few months ago, porcelain tiles on screed and I followed all the advise on here but since the kitchen, skirting etc has been fitted a few tiles sound hollow and I believe they have come unstuck. Because I don’t want to rip out skirting and kitchen I intend to try to take up the loose ones and re fix. My question is what is the best way to remove the grout, I think if if try lifting tiles without they will drag other tiles with them.
What is your situation on spares?
My tiler said chip out the tile starting at the centre to avoid damaging adjacents when replacing tiles.
But I am sure someone will have done it.
This chap suggests a Multitool with the diamond faced blade, but that is in "I may be gone sometime" territory.
Edited by Ferdinand
56 minutes ago, Mr Punter said:
If it just sounds hollow, it may be fully adhered over much of the tile, so I would either leave it (preferred option) or break it into pieces with a sharp blow in the centre.  What adhesive did you use and do you have UFH?
Its driving me nuts cause I know they are loose (other floor with different tiles is fine), used flexible adhesive with three coats of primer, yes we do have UFH but it’s not been switched on yet (on my extensive to do list)
Do all the tiles sound the same ? Eg ones a thud and another a clack ?
Get a a 1 mil grinder disc Nip the joints out make a hole Get a chisel under The tile should come out quite easy Chip away at the adhesive tgats left As long as the grout isn’t touching the good tiles
you’ll be ok
Some sound “solid” but some sound hollow, especially if you drop something on them, fork when washing up for example. I am just worried that if I start digging them up then tiles under the kitchen units or skirting will come up with them which will be impossible to sort without trashing my new kitchen.
Edited by joe90
Just can’t fathom out why they’d be popping. ?
Can you get a deffo hollow one up from somewhere at least slightly inconspicuous? Be interesting to see if the adhesive has stuck to the tiles and lifted from the floor / vice versa.
If you back buttered the tiles
There is not much more that you could have done
Don’t beat yourself up over it
Because a few have lifted it doesn’t mean the rest will
Not a big job to lift a few and reset them
Primered to death too though. ! Weird.
2 hours ago, CC45 said:
Good luck with that @joe90 - know the sound but I left ours there since they weren't causing any probs.
Thanks, they aren’t causing a problem apart from annoying me and the missus. I might not do anything with it yet as we are 90% finished but feel like 90% still to go! (Like Jeremy said ?).
We had a large format tile that sounded hollow in a previous house. The agreed course of action with the tiler was to drill a number of small holes through the grout around the problem tile and to inject a resin adhesive around and hopefully under the tile. It appeared to work as the hollowness was greatly reduced.
Aha. The second law of programming.
"The Last n% of a program takes (100-n)% of the time to complete".
I have a Plan F for you. Prevent all the echoes thusly, and save the repair time:
At this point I think I need to run and hide.
Edited by Ferdinand
  • Haha 2
I don’t know about you Nick
But once over we used to mix the grout like cream poor it on the floor and spread it out with a spatula To allow the grout to flow under the tiles Then we would scatter wood shavings to soak up the excess and polish the tiles to near perfect
That was my job for six months when I first left school No chance of any hollow spots
Now we mix the grout like paste and just fill the edges
Perhaps that why old tiles are such a nightmare to remove
I mix it a bit thicker than double cream and ram it into the edges and intersections by pressing down hard on the grout float. I do that until I see it pushing back up out of the adjacent grout lines so I know there’s not really any more grout that will ‘go’ under / in. Gets  a sweat on, but worth the effort imo.
I routinely dab each corner of the tile with a tablespoon sized blob of adhesive and let that ooze into the intersections and then sponge the excess back before putting the spacers in. I never put the spacers in so they stay btw, just one of the 4 legs in at about 50mm in from each corner so I can pull them out and discard later.
  • 1 month later...
What product was this?
