Leaky walk on sky lights
Pocster
Lol
I will guys !!
The builds not straightforward ( no sh*t) . Also there are other ‘edges’ that could let rain in . Starting to block pave towards the wall and hence flashing it ....
Edited by pocster
39 minutes ago, Declan52 said:
So it's not done yet. Could you not do that part first and see if that solves the problem.
What are you using as flashing??
A plastic angle I think it was he was using? Thought he'd done it tbh...
27 minutes ago, pocster said:
It’s actually a steel L ; angle grindded into the wall . Give me a chance ???
Have never seen flashing made from steel. Why not use lead. Easier to get into the cut as it will be able to bend up and down in case the cut isn't exactly straight.
