A week ago I brought a new level to make leveling the total station a simpler affair. Today I got it out of the case and the bubble was gone. I can see no damage to the case so I20180721_184826.thumb.jpg.94c84026e499e65ac0cd90697c40c9f4.jpg20180721_184826.thumb.jpg.94c84026e499e65ac0cd90697c40c9f4.jpg am now on the trail of the thief, any clues?
Pic - look no bubble!
Share this post
Link to post
First off, that level is nowhere near accurate enough to level a total station, you want one that can level to within far better than 1 deg, ideally one that can level to a few arc-seconds if you're looking to make measurements over any sort of reasonable range.
As for where the bubble's gone, then I suspect it's been dissolved in the fluid.  Try cooling it down and see if it comes out of solution.  Having said that, I'd still not use a level like that for anything better that levelling an orienteering compass...
Share this post
Link to post
Have you tried turning it over? :ph34r:
Share this post
Link to post
Send someone to buy a new one.  It happens all the time, I'm told :ph34r:
Share this post
Link to post
You could download an app and sit the phone on the level...
Share this post
Link to post
Sorry Jeremy. I use a bubble level to get the tripod within the adjust ment range of the TS leveling system no to set up the TS itself. It would, as you say, be useless for setting up the station.
It's in the fridge as we speak.
Share this post
Link to post
While you are at the shop getting a new bubble, ask for a long weight, and a tin of elbow grease while you are there.
Share this post
Link to post
That looks like a deckchair day indicator.
Or perhaps it is a highly targeted bubble. Did it go out of warranty last week?
Share this post
Link to post
Only if it is a Crapple one.
Share this post
Link to post
@newhome has a cistern full of them! :)
  • Haha 1
  • Sad 1
Share this post
Link to post
You b'strd......?
Share this post
Link to post
Well just as an update the 'thing' as I shall call it for want of a better word, it ain't a bubble level, has been in the fridge all night and it has not been visited by the bubble fairy. I shall revert to using my old cross bubble system until the suppliers have sent me a new bubble. Indeed, as  bit of fun, I will write to them and ask for a new bubble and see what they send me. Naturally I cannot return the old bubble as I have no idea where it is.
  • Haha 2
Share this post
Link to post
You joke but as an apprentice, after making our spirit levels we would be sent to the local engineering merchants in Erith to buy the 'bubble' for them like it was the most normal thing in the world. In fact the liquid filled glass / plastic tube. Same when I made my knurling took I had to buy the knurling wheels. I've still got the knurling tool somewhere.
Share this post
Link to post
You can actually buy bubbles for notalot:
https://www.ebay.co.uk/p/Highly-Accurate-Round-Turntable-Spirit-Bubble-Level-60mm-Diameter/874187491?iid=322065156124&chn=ps
And glue.
Though you will need to match the size.
Share this post
Link to post
Thanks for that idea, @Ferdinand, I broke the glass on my nice long cast iron engineers level a few years ago and have been hunting around trying to find a new one for it.  I didn't think to look on ebay...  The tube that holds the bubble on my level is adjustable relative to the big cast iron base, so it should be easy enough to calibrate it after fitting a new bubble vial.  Just a matter of finding one the right size and resolution.
Share this post
Link to post
Not easy finding a 90mm long, 15mm diameter, hi-res vial.  The level is a Rabone Chesterman 12" cast iron engineers level, essentially absolutely identical to the Starrett (I suspect Rabone Chesterman and Starrett may be connected somehow, as I can'r see the difference between them, other than my Rabone Chesterman is clearly stamped "Made in England").
Share this post
Link to post
Not impossible just bloody expensive!
https://m.ebay.co.uk/itm/Starrett-Level-Replacement-Vial-PT15024-for-98-12-98-18-Levels-/282815738579?
Share this post
Link to post
Well found!  I've been searching for at least and hour to no avail.  I found a UK supplier but the price was well over £40 plus VAT and delivery, so that looks cheaper.  Bearing in mind that a new 12" Starrett/Rabone Chesterman level is around £150 or more and the price for the vial doesn't look so steep.  I have found a complete second hand level that's identical to mine, except it doesn't seem to come with the wooden storage case, for £48 here: http://www.gandmtools.co.uk/shop/rabone-12-engineers-precision-level-80205536/  which has me wondering if it's not better to just buy that and keep my old one for spares.
Share this post
Link to post
2 minutes ago, Onoff said:
Thanks, another good find, but still £35 plus shipping and import charges, so the first link looks marginally cheaper.  Given the fragility of these things I'm surprised they aren't easier to buy here as spares - they seem easy to buy in the US.
Share this post
Link to post
Didn't mean to post that as a similar price but I've had a beer and was sleepy! Wrote it but thought I HADN'T posted it! :)
Share this post
Link to post
I CAN find lots of 70mm long, 11mm dia vials...
Share this post
Link to post
Me too, it seems that 90mm x 15mm diameter ones are like hen's teeth...
Share this post
Link to post
