Making Hole In Ceramic Sink
Onoff
Mate's kitchen:
The consensus on YouTube seems to be you punch a hole thru with a chisel and chip it out round by hand to fit the tap?
Is that right or would a grit edge holesaw be better? He's putting it off as scared of buggering his sink!
Cheers
37 minutes ago, Onoff said:
Mate's kitchen:
Cheers
I would us a diamond tiped core bit on slow speed in batterie driver
It will cut through like butter
Though the video looks effective
But could be his third attempt ?
One small hole with ceramic drill bit then use a diamond abrafile to cut the hole. IF there are any weaknesses in the manufacturing the Chisle method will find them spectacularly. The Diamond saw method is so much lower energy and controllable.
Chisel is the manufacturers recommended method - they create a weak point in the sinks to allow for this. The sink material isn’t tough enough in the centre to take a drill bit and it may wander and a grit edge hole saw will skip on the glaze and scratch it ...
If the hole is basically pre formed with only a glaze skin over the hole then the Chisle method has merit but of course the hole has then to go where put by manufacturer.
I was thinking to gently clamp a bit of timber underneath to centre the pilot of the hole saw and stop it wandering.
Prob is, your brain says use the diamond tipped drill. You convince yourself this is right.
Wrong.
The drill bit causes the glaze to shell off away from the hole edge and ruins the sink. Do as the manufacturers say and hit it out. Sharp, single taps almost a clout and bingo. It'll snap clean out.
They kind of put it where it needs to go ;)
I foubd a pin drift ( a flat faced centre punch ) the best. You won't smash the sink it's porcelain. If you cut with a holesaw you'll regret it. If you were supposed to cut with one the manufacturer would say so. They don't.
There you go thinking in straight lines again! If they put it where it needs to go why do they make you uncover it? Is it about size or could it be, for instance, to give the freedom to go elsewhere or, as on our kitchen sink, to have an addional tap for filtered water.
Is the sink maybe reversible. As in drainer on right or left. Would that mean two overflows?
Edited by Onoff
Don’t the overflows tend to be on the side of reversible sinks?
Reversible ones are why the knock out isn't done, but is half done both sides.
Normally it's a centralised overflow so maters not which side the drainer is.
Overflow only on one side with this so if you turned the sink through 180deg the overflow would be at the front.
CT1 or Sikaflex EBT or standard silicon to bed this into the worktop as it doesn't have any clips?
Cheers
Clear CT1 to bed it in for fixing purposes, and wipe back with the baby wipes. Have a look at the casting and see if the shadow gap isn't excessive, if it is then wipe a bit deeper and leave to dry. Then finish with a bead of ( cosmetic ) white silicone which can be refreshed when necessary.
12 minutes ago, joe90 said:
Just read this as I am about to fit my sink, takes a bit of guts to hit a new expensive sink with a hammer ?. But here goes !,,,,,,,,,,,,,,,,,,,,,,,
As least you know it can be done like they say!
I'd hit the weak point with the punch NOT the hammer!
Edited by Onoff
  • Sad 1
