Basin Wrench?
mike2016
Hi,
Plumbing 101 question! I fitted a water filter under the kitchen sink which feeds a separate tap. The new tap is still a bit loose and can swivel easily. I need to tighten the nut under the sink but it's at the back left of the sink unit.
Simple question - what's the best tool to use? Should I buy a basin wrench or try with a pliers?
Thanks!
