mvhr general question
I see lots of photos posted on here of various MVHR systems, they all seem to have some form of silver foil wrapped round the big pipes coming from the unit. I have no silver foil on mine.......please what is its purpose and do I need it.
System is due to be commissioned in a couple of weeks so if I need to ask a question of the installer its the time to do it.
Thank you!
Pipes that pass through an un heated part of the house should be insulated.
Also the big pipes between the inlet and outlet and the mvhr unit should be insulated even if in a warm space (as they will contain cold air)
Some forms of insulation for this have a foil wrap, but not all (mine don't)
5 minutes ago, lizzie said:
@NSS that armaflex looks a good idea the polystyrene doesnt seem to be very substantial. Did you add that or was it supplied as part of your system?
It doesn’t need to be thick - it just needs to keep the steel at a temperature close to  the incoming or outgoing air. You may find the duct is actually made of polystyrene - certainly has that look about it. It’s pretty strong as long as you don’t hit it ..!
