Decrement Delay
bissoejosh
  • 6 months later...
I'm still unable to make the calculator work for some reason having tried again, the drop down boxes aren't available for selection and a message claiming protected cells cannot be modified stops me in my tracks.
Would someone with a spare 2 minutes who can use it mind doing a calculation comparing the following wall build ups?
20mm Larch cladding
100mm cavity
11mm OSB
300mm Warmcell vs  3 x 100mm Rockwool flexi Batts (0.038)
11mm OSB
38mm Cavity
12mm PB & SKIM
I'd like to know the difference replacing the Warmcell with Rockwool would make in terms of house comfort but can find no other calculator online to try.
Many thanks
Edited by bissoejosh
20mm Larch cladding
100mm cavity
11mm OSB
11mm OSB
38mm Cavity
12mm PB & SKIM
Many thanks
Whats the U/R value of Warmcell..?
I think you are asking the wrong question really.
But after a quick look on the internet, both Warmcell and Rockwool CAN have the same R-Value and Density.
So that means they can have the same thermal properties, the airtightness may vary. That should have been taken car off anyway by your basic construction method.
