Rodent Barrier Suppliers
Triassic
The stainless steel wire wool rodent barrier located behind the base of my larch cladding, turned out not to be stainless at all and has started to rust and fall out. Can anyone suggest a supplier of  1” wide stainless steel wire wool, so that I can replace the rotten stuff?
I've got a roll of stainless steel wire wool you're welcome to, but it's IIRC about 150mm wide. I just unrolled a length cut it and rolled it into a sausage shape to put behind my cladding. Trouble is I'm about as far from you as it is possible to be in England.
Thanks for the offer, pity you’re so far away.
