So we are going to install a 500l thermal store into the utility room. This will create quite a bit of heat I suspect and it would be good to spread this round the building. In fact next to the utility is the integral garage which is full insulated - 60mm internal insulted PB, triple glazing and an insulated garage door. Would it be mad to put a single room mvhr system between these rooms to gentle heat the garage with the excess heat from the the TS?
Yes
purely because of the initial outlay, the idea isnt bad but it will NEVER pay for itself,
a few hit and miss vents may not be a bad idea but actually pumping the excess heat into a garage. I very much doubt will be cost effective
