Is this the chance to buy some new tools?
MikeSharp01
Just about to start, the boards arrive tomorrow, fitting the Plaster Board (PB) to the internal framing which I have created folowing my previous post on drylining. So I guess I need the tools and techniques.
1. What is the best way to cut plasterboard - is it just Stanley knife or should I get a saw of some sort.
2. When cutting out for sockets etc is there are a technique and again a tool.
3. There are only 40 boards in the garden room but 170 in the house. Is now the time to buy the collated screwdriver
Any suggestions?
Our guys just scored the boards with a knife and long straight edge, then snapped them.  The only sawing was when making the cut outs for sockets, switches, etc.  The technique for marking these on the boards (provided the boxes have been correctly fitted so that they protrude into the board) is to cut the board to size. put it in position and then thump it where the box is.  This marks the back of the board so that the cut out is in exactly the right place.
A collated driver is a must, as you'll get thoroughly sick and tired of trying to do this single-handedly without one.
This - " just scored the boards with a knife and long straight edge, then snapped them" - and take your time on making the score.
I have seen this too - "put it in position and then thump it where the box is" - the plasterer told me it just takes a little experience and courage. ;) - neither of which I had when I did our old utility area!
Buy this...
http://www.ebay.co.uk/itm/Senco-Duraspin-14-4v-auto-feed-collated-screw-gun-/272782031008?hash=item3f831378a0:g:yLIAAOSwtFtZfDkI
New Batteries are £18 from County Battery, and they are bullet proof. I bought one and refurbed it with bits from the US for less than $20
Edited to add :
Or this one... http://www.ebay.co.uk/itm/SENCO-DS202-14V-DuraSpin-DS202-14V-Cordless-Collated-Screwdriver-/282622613945?hash=item41cd9ed9b9:g:EcgAAOSwLzhZniWZ
Edited by PeterW
Added Link
Sharp Stanley long straight edge. Snap and fold then run the knife up the fold from the other side.
Get the little yellow surform plane from Screweys for adjusting edges:
http://www.screwfix.com/p/stanley-surform-block-plane/20388
I use the mutitool for sockets.
Yes to a collated gun. Welcome to borrow my Parkside corded one to try.
That Dewalt isn't the collated one - it's the bare one with just the setting drive on it from memory.
You need the collate feed for it.
I'd drop the £30 on that fleabay one that's up the road and then buy a new battery for it .. Senco stuff is good ....
Senco screw gun has been great - Easy fix Collated screws are duff,  the Technofast ones are far better. I've gone through about 30,000 so got a good feel!
Also, I recommend a Bessey folding  knife. Best knife I've ever used and beats any Stanley. Very quick to change blade. Been using ours for two years and mechanically as good as new. Buy plenty of blades to give effortless cutting!
Agree with score,  break and run blade up other side.
Sounds like a plan but we are dry lining so boxes fixed from front but at least I can choose the place - cutting out sounds like the multitool approach suggested by @Onoff. (will be supported locally above and below by horizontal battens)
@PeterWIs it the Ryobi battery - they seem not have the Senco stuff
1 hour ago, PeterW said:
Buy this...
Edited to add :
I have the Senco and it is a great piece of kit. Just keep checking the drive bit is ok to ensure good contact with the screws.
P.S. if you really want to spoil yourself grab a blade runner. It is really clever and a big timesaver. No need for a straight edge and no need to cut both sides. Finding one in the U.K. Can be the tricky part.
http://www.toolsofthetrade.net/hand-tools/cutting-tools/first-test-goldblatt-bladerunner_o
Edit: evilbay to the rescue:
http://www.ebay.co.uk/itm/Blade-Runner-Plasterboard-Cutter-/332354544556?epid=1907615876&hash=item4d61dfe3ac:g:vJwAAOSwBlxZnYwH
Edited by Barney12
@MikeSharp01, you should know better than to come on BH and ask stoooooopid questions like that. I mean, who is going to say,
"Naaah mate, just struggle on with a teaspoon, that'll do: I used a bent one, it was free cos I found it in the gutter: I sharpened it  by rubbing it on a mermaid's thigh for 6 weeks."
Instead you get:
Bingo....
"Look Darling, Jeremy says we should get one, so I'm off down the BM...... OK? :ph34r:
  • Like 3
12 minutes ago, recoveringacademic said:
Plenty of the corded, collated screw guns in Lidl Sevenoaks still
Yes I saw them last weekend. Might get one for the hell of it. Sorry that should be an @Onoff quote not sure what happened there.
Edited by MikeSharp01
Misquote
"Naaah mate, just struggle on with a teaspoon, that'll do: I used a bent one, it was free cos I found it in the gutter: I sharpened it ...
Very funny!
have you got/ looked into a board lifter?
http://www.ebay.co.uk/itm/Drywall-Panel-Plaster-Board-Sheet-Hoist-Lift-Lifting-Lifter-Construct-Tool-11ft-/253098500094?epid=2185774479&hash=item3aedd89ffe:g:jr4AAOSwRztZk8jg
:ph34r:
There were seriously posh people in there earlier, the woman exclaimed "Oh look Roger they do TOOLS!" They then stood there enthusing about a ratcheting, multi size, fits anything spanner thing.
