Pocster Posted June 28, 2017 Share Posted June 28, 2017 (edited) Hey all, Looked online but can't find the answer for this. Due to some complications my bathroom door might have to be narrower than usual. I *assumed* this might cause an issue for BC (not going to ask them and draw attention to the problem!); due to wheelchair access. Do *all* building have to have min width doorways for wheelchair access (I can understand on a bungalow) but on a house with stairs?? Or is it at BC's discretion ? Cheers p.s new build Edited June 28, 2017 by pocster Link to comment Share on other sites More sharing options...
Jeremy Harris Posted June 28, 2017 Share Posted June 28, 2017 For a new build there's no real discretion, other than a bit of minor deviation allowed by assessment by the building inspector. The minimum opening widths and the access space inside the WC has to meet the dimensions in the diagrams in Part M. In our case I increased the dimension once side of the WC and ended up about 20mm short of the minimum dimension on the other side, but that was done on the advice of a wheelchair-using friend, who tried it out for us and said he'd rather have more room on the side nearest the door. I explained this to the building inspector during the completion inspection and he was happy to sign off on it. I'm pretty sure he wouldn't have accepted a narrower clear opening width, though. Link to comment Share on other sites More sharing options...
PeterW Posted June 28, 2017 Share Posted June 28, 2017 15 minutes ago, pocster said: Due to some complications my bathroom door might have to be narrower than usual. [...] 15 minutes ago, pocster said: Do *all* building have to have min width doorways for wheelchair access (I can understand on a bungalow) but on a house with stairs?? Or is it at BC's discretion ? Cheers p.s new build I thought you weren't doing a new build but a renovation..?? If so, Part M doesn't apply. Link to comment Share on other sites More sharing options...
Pocster Posted June 28, 2017 Author Share Posted June 28, 2017 1 minute ago, PeterW said: [...] I thought you weren't doing a new build but a renovation..?? If so, Part M doesn't apply. No it's a new build. Just taken so long it seems like a renovation! Link to comment Share on other sites More sharing options...
Pocster Posted June 28, 2017 Author Share Posted June 28, 2017 12 minutes ago, JSHarris said: For a new build there's no real discretion, other than a bit of minor deviation allowed by assessment by the building inspector. The minimum opening widths and the access space inside the WC has to meet the dimensions in the diagrams in Part M. In our case I increased the dimension once side of the WC and ended up about 20mm short of the minimum dimension on the other side, but that was done on the advice of a wheelchair-using friend, who tried it out for us and said he'd rather have more room on the side nearest the door. I explained this to the building inspector during the completion inspection and he was happy to sign off on it. I'm pretty sure he wouldn't have accepted a narrower clear opening width, though. Thanks. The bathroom internal space is no issue. Link to comment Share on other sites More sharing options...
Temp Posted June 28, 2017 Share Posted June 28, 2017 Part M 2015/16 edition... https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/540330/BR_PDF_AD_M1_2015_with_2016_amendments_V3.pdf Page 7 section 1.15 suggests that there is a minimum width for "all doors to habitable rooms" and the "WC on the entrance storey". I don't think a bathroom is a habitable room so I think you are ok. Best check I've read that correctly. Link to comment Share on other sites More sharing options...
Temp Posted June 28, 2017 Share Posted June 28, 2017 https://www.designingbuildings.co.uk/wiki/Habitable_room Approved document F, Ventilation, suggests that a ‘habitable room’ is: ‘…a room used for dwelling purposes but which is not solely a kitchen, utility room, bathroom, cellar or sanitary accommodation.’ Link to comment Share on other sites More sharing options...
Pocster Posted June 29, 2017 Author Share Posted June 29, 2017 21 hours ago, Temp said: https://www.designingbuildings.co.uk/wiki/Habitable_room Thanks Link to comment Share on other sites More sharing options...
