old buildings wooden lintels
A 200 deep concrete lintel will support most
Though I’ve worked on stone bar conversions with thick stone walls and a row of four 100s have been used over windows and doors
12 hours ago, SteamyTea said:
Here is a timber beam calculator.
https://www.timberbeamcalculator.co.uk/en-gb/calculator/timber-beam/british-standards?new
Work out what you already have, then look for a concrete one.
https://www.naylor.co.uk/products/lintels/lintels-selector/
that calculator does not list OAK   or teak ,probably from old sailing ships and things at 14" wide and 6" deep
maybe me ,but I can,t make any use of it
 and how do i calculate the load of the granite stones on top of it -- Iwas looking for a rtaight foreward com[parison .
will probably just replace wood  oneswith pre stressed lintels to make up same dimensions ,maybe 3 or 4  wide where needed
Edited by scottishjohn
https://www.engineeringtoolbox.com/wood-beams-strength-d_1480.html
Measure the size to get the volume, multiply by the density, then multiply by gravity.  That gives you the force in Newtons.
Then measure the width ad length of the lintel, in meters, to work out the surface area.
Then divide the N by the m2 to get the N.m-2, AKA pascals.
Edited by SteamyTea
I wouldn't try and compare timber to concrete. Just assess each opening on its own merits compared to the load rating of the lintel.
The lintel manufacturer or a structural engineer can assist with this.
