New windows, triple glazing?
HughF
On 06/05/2022 at 19:27, john0wingnut said:
Potentially looking at this window supplier. Also found eurocell home and supply only windows, but haven’t scoped them out properly yet. Modus system you can get 0.7 U value 3G windows.
If the whole of eurocell is the same as my local branch, they only supply AGC glazing now, which will only get you to around 1.0U, so to achieve this you would need to source the glazing from somewhere else.
  • 1 year later...
Tiled/cold bridge/poured in situ concrete sills removed, cavities stuffed with some more rockwool, windows fitted with compriband and fm330...
Making the best of a bad situation.
